Chri5peed
- Sep 16, 2005
Team Lossless FTW!
![600smile.gif](http://images/smilies/http://hfimage.head-fi.org/smilies/newsmiles/600smile.gif)
Originally Posted by Chri5peed Team Lossless FTW! ![]() |
Originally Posted by dknightd I use mp3 because it seems to be good enough, and takes up less room, and can be played on almost everything. If somebody can point me to a abx comparison where anybody could tell the difference between 320kbps mp3 and lossless I'd love to hear about it. |
Originally Posted by Skylab That isn't necessarily the point. For portable listening, sure, what you said makes sense. But for archiving (and hence listening on the PC), using a lossy codec does not make sense, since lossy codecs will continue to improve, and once you rip in Lossy, you can never take advantage of those improvements without re-ripping. |
Originally Posted by Xakepa Your loseless recording will be just as lossy as MP3 once the same old recording is "digitally remastered" to 24/192 DVD-A, SACD, AAC or whatever format comes next. |
Originally Posted by Skylab and once you rip in Lossy, you can never take advantage of those improvements without re-ripping. |
Originally Posted by bigDee How, wouldn't it still be a transcode if you encoded from flac to another codec? Anyway, I am no fan of lossless. I don't see the point. If you can't hear the difference between lossless and 320kbps CBR, then what is the point? Having a perfect archive of your music seems like a way to be some uber elitest. There's just no point. If you can't hear the difference now, no matter what happpens, even if stock headphones of the future are 10x better than they are now, you still won't hear the difference. You can't hear the difference on any kind of gear. There is just no point. Perfect archive is pointless. |
Originally Posted by Xakepa Ohhh, this argument's been around 100 times. Your loseless recording will be just as lossy as MP3 once the same old recording is "digitally remastered" to 24/192 DVD-A, SACD, AAC or whatever format comes next. It's our brain that sets the limit, not the technology. By any means modern MP3 codecs exceed brain's limit, so there's no point to go beyound. It's no different from assertion that we can "percieve" freq above 20KHz |
Originally Posted by Skylab If you ripped in MP3 320k, it may sound perfect to you. But if you them want to transcode to AAC 192 for some reason later, you will SERIOUSLY compromise the sound quality... |
