I cannot think of a good reason not to purchase an iAudio X5.
It is not the best player, but it has good features over what is
currently available.
I have been saving for a new DAP also (to rest my fav iRiver H120.)
It is a toss up now between the iAudio X5L (hopefully in the 30GB, or higher
capacity versions,) or the Sony HD-5 or Vaio Pocket. The only thing I don't
like about the Sony DAPS are the dependent loading poor software. But the
price is right for the Vaio Pocket 40gb $249.99 straight and dropping.
However, I like the USBOTG fuctionality and the Vaio Pocket doesn't really
have that functionality, and I need the drag drop easy way of loading the
player (The Sony DAPS allow drag and drop, but I don't think that the audio
files loaded via drag and drop are playable through the Sony DAPS, the SONY
DAPS will load the files into a data folder. Only songs loaded via SonicStage
or with the Vaio music handler software can be played by the DAPS. I think.
The Vaio loads via drag and drop with a Vaio software application, but you need to load that software along with SonicStage on the other computers you plan on loading from or uploading to. Too cumbersome.)
True USBOTG support allows the player to be connected to other players, other USB storage devices, computers, etc. without software dependence which I (and others) are interested in.
The iAudio X5 looks very good for: battery duration, multiple audio format
playback including LOSSLESS, user settable EQ, playlists-on-the-fly, drag
drop no software needed to load the player, true supported USBOTG, clock
with alarms, video playback, audio line-out, and CONTINUED FIRMWARE
SUPPORT with more features to be added.
I have yet to read a head-to-head comparison between the
X5/iRiver/Sony/Ipod/Creative/Karma/etc.
offerings. Just posts that report that the X5 sounds favorable over some of
the current offerings.
Can anybody else can compare this player with others, with more new
PICS!!!!??????
Thanks!
