bigshot
Calibration is an objective measurement that doesn't take any perceptual issues into account. If you are going to start a mix on a stage in New York and finish it on one in Los Angeles, you want the frequency response of the two stages to be calibrated the same.
Fletcher Munson applies to every human being. The mixer in New York is mixing to his ears that are subject to Fletcher Munson, and the guy in LA is too. Most mixers work at a reference level that is fairly loud. That is what they mix to optimize. Fletcher Munson isn't an issue for either calibration or mixing.
Therefore, if you calibrate your response curve and listen at a fairly loud volume you are hearing what the people who made the recording intended.
If you want to playback at a low volume, you need to apply loudness compensation. You do that by turning on the loudness button. If you have a recent amp, that button works dynamically, so there is more loudness correction applied at lower volumes and less at higher ones. Just turn that on and you don't need to ever even think about it. It just does its job. Loudness compensation is applied by the listener. Not the engineers.
Is that clearer to those who are confused? (even the ones who are confused but don't realize it!)
