Syzygies
- Nov 16, 2004
Very 2am, but no one mentions it: Pick some solid wire that just fits the hole. Reinforce the extra to hang onto so it won't buckle. Or use plyers and a scrap resistor lead. Securely clamp the board, and pick the direction to push to avoid pad damage. Heat the hole, plunge the wire through pushing obstacles out. Clean up both sides with braid as much as feasible. Now reheat and slip out the wire, using iron tip to support pad that could damage.
I've done this on protoboard, which is extremely fragile, and ended up with a circuit that worked. Certainly the long way around the mountain if one is good and has the right tools, but who's good and has the right tools at 2am?
I like the blast of compressed air. I had the can and didn't think of it...
