Rameish
- Jun 22, 2001
1) Price of components are not the same for every manufacturer. Eg; Rotel may buy 50,000 pieces of a single cap each month and have a contract with the cap manufacturer for 50,000 of the same for each month for the next 12 months.
Someone like Grado, Meier Audio or Headroom WILL buy only a fraction of that.
Probably less than DIY retail (not for all components). I do not think you'll get much of a discount is you bought 100 pieces of Alps volume pot for eg. Not as much as if you bought 20,000
2) Most are hand built in developed countries. Rotel, Marantz etc manufacture in China - labour cost are quite different.
3) Profit margin to make it worth their while after considering rent, labour, parts, excess inventory (money tied up and as such it is an opportunity cost).
All in all, yes they are expensive but you really can't compare an apple to an orange. This is true of any industry - watches, cars, hi-fi, furniture, hell even grass!! Do you know how much it would cost to have your own putting green
BTW If I has a Senn HD-580 I would stay away from the 3 volt or 4.5 volt versions of the Airhead. I have an older 3 volt version (2 AA batteries) and it simply can drive my Senn HD-530 MkII. It works okay with Grados however.
So I would suggest either shell out the money for a second hand Porta Corda, Total Airhead (9-Volt version), or Airhead (9 Volt version). Patience and caution are the key words if you wish to buy used.
