Omega
- Apr 14, 2004
Many audio cable designs aim to employ low dielectric shields around the conductor. Why?
Background: The dielectric value is a constant placed into equations describing how the electrostatic field at one point in space will propagate to another point in space. Wikipedia does a decent job here:
Relative static permittivity - Wikipedia, the free encyclopedia
Higher dielectric = higher amount of "charge screening" = less transmission of charge.
My hypothesis: When used as cable insulation, higher dielectrics encourage higher capacitance along the direction of the conductor. Capacitance is frequency-dependent and can cause non-linear attenuation in the cable. Non-linear attenuation should be observable in cables of sufficient length or signal strength.
Questions: Can anyone provide insights, anecdotal experience, or actual data to support (or reject) the hypothesis? I'm trying to understand why audio dogma says low dielectric cable insulators are superior, and get a feel for the magnitude of that effect. Is using an insulator with a dielectric constant of 4.0 twice as bad as a dielectric of 2.0?
If the discussion enters forbidden territory for DIY forum, apologies, I'll withdraw it and forget I asked . But I think it is important to build things with at least a basic understanding of *how* they work...so this should be a relevant question to anyone here building cables or electronics with internal wiring. Really, this is akin to discussions of whether a particular output transistor or opamp affects sound, etc.
To facilitate discussion, here are dielectric values for commonly used cable insulators and other known materials:
water: 78
ice: 4.1
nylon: 3.5 (approx.)
polyvinyl chloride (PVC): 3.0
paper: 3.0-3.5
(butyl) rubber: 2.35
polyethylene: 2.25
vaseline: 2.16 (Ha! love to see this used on a cable!)
Teflon: 2.1
air: 1.00
water: 78
ice: 4.1
paper: 3.0-3.5
polyethylene: 2.25
Teflon: 2.1
air: 1.00
