StanD
- Oct 2, 2013
It's a 64-bit sample engine.
That doesn't say how it processes samples of lesser bit depths or different sample rates.
I think the main reason they stick with groups of 4-bit is because it's easier to join double word-byte values than singular length bit.
Although this has always been possible for a long time, it probably hasn't quite as accurate and more squared off than analogue sounds in comparison. Vinyl for the moment is the king of dynamics however with DSD and analogue amplification it may be a different story.
The Oohashi results have never been verified/replicated and Oohashi's follow-up lacks enough details to assess it accurately, however with direct bone conduction you can get detection of frequencies not normally audible...
Also did you know, the lower harmonics of a turntable can be as low as 10Hz.
Maybe so, but that 10hz is hardly going to be a clear, well defined note. It is not possible for any turntable to reproduce frequencies below 100hz that are accurate. The vinyl medium and its ability to store this information in the grooves is just one limiting factor.
Lower Harmonics? A Harmonic is a whole numbered multiple of a lower fundamental frequency.If so what is the fundamental frequency that you are referring to?
So yeah...assuming it was even possible to get 32 ENOB from a DAC with some kind of sci-fi magi-tech...
Dynamic range = 32 bits * 6dB + 35dB background in a quite room = 227dB SPL...
Which is higher than the maximum limit before it turns from "sound" into a flatout shockwave!
Which thread were we talking about the sonic weapons in again?
If AnalogSurvivor can survive that, my hat's off to him.t
There seems to be some confusion between dB SPL and dB FS not to mention the background noise that doesn't exist with headphones, so, you'll have 192 dB DR... witch is nothing for a guy that can hear 50kHz while listening a XVII century harpsichord in a chapel with no background noise.... and by the way, what is that thing... background noise...? isn't it part of the music?
and ...can tinnitus be considered as background noise? or is it a constant that can be disregarded?
I want to listen to the CD MATS test files AnalogSurvivor... can I expect them by Christmas?
You'll play that harpsichord for WhaleBats on a CD Mat before AanlogSurvivor delivers.
10Hz is the about where any motor resonance from a belt drive would be. 7
