I'm not sure exactly what you mean. I have several image editing programs that will happily display the RAW images from all of my cameras.... as will most of my image viewers.
And, while my Nikons have a pretty good dynamic range, a good modern TV can match it (DSLRs don't tend to have an excessively wide dynamic range - although some of the new video cameras are much better).
But, yes, I always convert them to something else "for distribution".... because a lot of displays won't.... and, having the part of "the recording engineer", it is my decision to make.
(And there are also a few situations where no current camera can handle the dynamic range - then we use HDR.)
And, again, we're back to my original point....
How do you
KNOW which noise was made by the instrument and which was an artifact?
As a recording engineer,
MAKING music, you can easily decide if you
LIKE a particular sound or not.
However, as someone arranging to
REPRODUCE it, I (or the customer) should not.
I have one recording that, in one part, has an odd little noise that sounds very much like a midrange with a jangled voice coil.
However, it plays the same on multiple speakers, so it's really part of the recording.
In fact, when you turn it up, and listen carefully enough, you can tell it's something vibrating on the drum kit.
I'm not sure why the recording engineer left it there - but I'm glad that it didn't mysteriously disappear when it passed through my equipment - because then my reproduction of that recording would be incorrect.
I may
DECIDE to make a copy with that noise edited out - but I want to make that decision consciously if at all.
I never implied that any given surround sound mix is wrong.
In fact, by definition,
WHATEVER the engineer did is "right" (which doesn't mean that I have to like it).
However, strictly speaking, other than possibly binaural, both stereo and surround sound fall short of being an accurate reproduction of the original.
The original was a bunch of sounds, produced by a variety of different instruments, each of which interacts differently with the room.
Neither a stereo pair of speakers nor a set of surround sound speakers can reproduce the complex radiation and reflection patterns accurately.
Therefore, both are a compromise, where we do our best to do what we can accurately, correct for or null out the obvious discrepancies, and hope for the best.
But, no, I have never heard a system, at any price, or with any level of detailed setup, where I could honestly say:
"If I dragged the conductor of that performance into my listening room he would not be able to tell whether this was a recording or a live performance."
I would consider both the stereo and surround sound mixes to be "artistic renditions of the original" - so the best we can do is to reproduce the mixing engineer's intent there.
We seem to be agreeing that no recording is perfect...
Therefore, it would seem logically obvious that it must follow that "there's room for improvement"...
In fact, I suspect that I more or less agree with your priorities (except that I prefer stereo to surround).
However, I'm also not prepared to declare that any area is "so perfect there is no possible room for improvement".
I think our biggest point of disagreement may be in your "faith" about modern equipment.
I've owned a lot of DACs..... many of them sound very similar... and many sound very obviously different.
In some cases, the differences in sound can be clearly traced to specific obvious differences in specifications, but in others it seems less so.
For example,
MOST of the units I've owned that used the Sabre DAC chip have had a distinctive sound....
(Since the company who designed the chip originally claimed that they'd chosen their filter characteristics based on "what people liked in focus groups rather than what was the most numerically accurate", I see no surprise there.)
My problem is that, of the two dozen or so DACs I've owned, about half of them had a distinctive sound signature of one sort or another.
And, while I think it might be interesting to do the research to figure out where those differences come from, I'm too lazy to do so.
However, from my experience, it would be untrue to say that "all modern DACs sound the same" or even "
MOST modern DACs sound the same".
I'm much more comfortable saying that "some modern DACs sound the same, and many sound quite similar, but you shouldn't ASSUME that a given one does without finding out for yourself".
(Sadly, I'm forced to suggest that people find out for themself, even though we all know people have all sorts of biases and odd notions, because reviewers seem even more prone to odd opinions, and the commonly available specs don't seem to tell us quite enough - at least not yet.)
Except that's not how this works. Your RAW is not displayable at all. Just to see it and make your judgement of what you think you want to discard you have to throw information out.
I've never once argued against keeping the RAW image. It's what I do.
But it's actually not. You just need to learn what to look for. What you're doing when you process a RAW file for display is making that choice, either you or your computer, but it's already being made, and quite intelligently.
You've once again missed the point entirely. If the noise is from an instrument, it's probably not an artifact, it's made by the instrument. If the noise is form electronics, it's not part of the acoustic event. If the noise is audible, it's a flaw, a defect, but likely nothing we can do anything about. If the noise is ultrasonic, it's not part of the original event AND something we can eliminate.
That's fine. As when I have my engineer hat on, I make those decisions all the time, and you already know what I'm going to do.
You need to study this a bit more. You're implying that an engineer's surround mix is somehow wrong, and that's incorrect. Surround sound includes a rather well standardized speaker layout that even you can follow. And standard calibration. And even known play levels. With those tools alone you can stand a far, far better chance of hearing what the engineer heard, and that is, in fact, the goal of some higher end home AV systems. That goal does not, and cannot exist in two channel stereo. And we're ignoring all the rather important issues of phantom imaging (or the lack of). I'm surprised that you don't understand all of this given your connection with your employer.
And I want to over capture too, to preserve as much of the information of the original event as possible. I don't want to capture more of what wasn't there in the first place.
You might consider not doing any more imaging analogies, you don't seem to understand printing or image processing. I get what you're trying to say, but your analogy is horrendously out of touch with reality.
Here's where we differ a lot. You don't seem to feel comfortable with your understanding of what is and is not audible. In the tape days it was easily provable at any point in time that the system was not perfect or even adequate for capturing the original. Anyone making the claim above was deluded (though clearly very happy with his gear). The medium was vastly worse than its input signal. Today we can still easily prove what's audible and what's not. Our digital medium is also measurable, provable, and verifiable as to its efficacy and deficiencies. You seem to think that knowledge doesn't exist. So you slap more resolution on it as a solution, when it solves nothing, and creates further potential problems.
You admit that the production process is out of your control. So, then, why are we even arguing? You'll take what we give you and like it...or hate it (I'm sure there's no neutral).
Pretty sure we've both bought multiple version of material hoping for something better or different. That goes back the the tube/vinyl days, nothing new there. One of my favorite pieces of music was recorded in the 1950s, and the original RCA pressings were only fair. I bought several pressings, none were good. Decades later I got the CD. Guess what? The same distortion I didn't like on vinyl was perfectly preserved in bits! They pushed the record level into tape saturation.
Ultimately you have two choices: take it or leave it. Hey! That's a binary decision! You should have no trouble with it.
