castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
to be clear, almost nobody cares that a file is at 44.1 or 48khz, take price increase and storage cost/limits out of the equation and I'd be fine with DXD on my computer. why not? if it has no negative impact why should I care which format it is? you won't find many people going "oh no I have better resolution without any negative impact, what will I do?" ^_^I've got to mention something here.........
I simply don't understand why some people seem so resentful about this entire subject.
I've never driven my car over 90 mph..... yet I still see no reason why it's "bad" that my car "can" go that fast.
In general, in almost every other subject, most people agree that you're better off if your tools can actually deliver, not just adequate performance, but performance that's BETTER than necessary.
It goes by names like "safety margin" and "margin for error" and "headroom" and even "clearance".
And who would really buy a car that can only go 56 mph?
So, why, even if you believe that we can't hear above 20 kHz, is it so awful to allow some safety margin.
If I were recording bats, and found out that their cries extended to 46 kHz, I would buy a microphone whose response extended to 60 kHz; I wouldn't buy one that went up to 46.1 kHz.
So, why, even if humans can only hear to 20 kHz, doesn't it make equal sense to make recordings that extend "well above" 20 kHz..... just in case.... to leave a little safety margin?
Why would anyone specifically choose to use a sample rate that's "just barely good enough"?
There is a reason why the 44.1k sample rate was chosen for CDs.....
The reason is that, with the constraints of the technology at the time CDs were invented, the time/space constraint on CDs was considered to be important.
They couldn't have used the next-higher standard sample rate without reducing the storage time on a standard CD below one hour - which had been established as a target requirement.
Using the 44.1k sample rate, they were able to fit over an hour on a disk, and still deliver frequency response that was a tiny bit above the bare minimum necessary.
The 48k sample rate was already in use on DAT tapes, and was considered to be a sort of standard; they would have used that except that, if they had, they couldn't have fit an hour on a CD.
In fact, most movie audio (on DVDs) is still standardized at 48k.... and not 44.1k.
However, when you're talking about download FILES, that constraint simply doesn't exist.
(in fact, even originally, it was strictly tied to "fitting a complete album on a CD")
your argument that I understand, is that there is no point nowadays in risking it all on the lower format. it's simple an intuitive enough. also it's an opinion so it doesn't have to be right or wrong and we're all free to have our own.
but then I read stuff like this:
and I angrily raise my fist in front of my screen with about the same impact on you that high-res tends to have on my ears. I purchase music for the sound I perceive, not to look at a spectrum in owe. so when I fail to perceive a difference(consistently over several years), the 96k file is worth to me exactly the same, not 5$ more. on the other hand if every 3 albums the 44 or 48k version saves me enough to buy a 4th one. now that's audible evidence right there, and it will pass all blind tests.What's the big deal about paying an extra $5 for a 96k file instead of a 44k file?
