mmerrill99
Member of the Trade: M2 Tech
- Mar 2, 2006
And what guides you to "imagine A possibly having a certain characteristic over B" - just random thoughts?
It was right on top of your head--"The initial tipping point may have been caused by you slightly unseating your headphones or moving in your seat, changing the acoustics from A randomly over B;", although random mood swings can serve just as well
Ah, "]self-priming confirmation bias" what is this a confirmation of - an expectation, perhaps?
Not an expectation in the sense of your expectation of whether there is a difference or not going into the test--but the expectations that can be set up by the random process described above--always favoring a difference. Once a difference appears because of some random fluctuation, your brain latches onto it, expands on it and continues to insist on it long after the initial difference has disappeared into the noise.
If it's just random events, as you suggest, then we would see just randomness in people's sighted listening & no particular device/protocol would be favoured more than any other!!
