afobisme
- Aug 27, 2005
where?
Originally Posted by Bob_McBob Still available "elsewhere"... |
where?
Originally Posted by marvin Nope. But throw in all the people who have long commutes, live in cold climates, do very little driving, do lots of driving, do lots of long ranged driving, and/or live in areas without the necessary infrastructure to support electric cars and it's well above 10% of the population. |
Originally Posted by IEATTEFLON I just wish they brought out more hybrids that actually looked like a regular car. Most of the ones that I've seen seem to be designed with bubbles and the Jetsons in mind. |
Originally Posted by blessingx Okay, cold climates is a very good point. Otherwise if we conservatively take half the stat given in the film (at end of SV1s life), how many often drive over 150 miles a day and don't have access to a power outlet? In fact the infrastructure is used as one of the reasons hydrogen is a far less user friendly solution to electrics (which you can plug in at home? And [conspiracy theorists get ready] why it's more difficult for energy companies are control. If the film can be believed (not sure how many commenting have seen it) the battery life at point of SV1s death could have outlived the average expected body life. |
Originally Posted by marvin Infrastructure is a wash between electric cars and hydrogen cars. The main producers of hydrogen would be the oil companies (where else are you going to be able to find that much energy?) and gas stations can be converted into hydrogen stations. For electric cars, there'd need to be a large increase in electrical generation capability to provide enough capacity for everyone's electric cars. If you wanted fast charging electrics, home wiring would also have to be upgraded. |
Originally Posted by nikongod for the present, neuclear power plants provide most of the hydrogen as a convient use of a byproduct. how good is hydrogen as a fuel? fast charging? easy. build a BIG home battery of any stable type you like, and trickle charge it as you needed. when you get home "dump" your load into your car, and drive off. as a bonus this could be wired into solar cells, and used as a back-up-power suply device for the house... you dont ahve to have an "industrial" power suply line to charge a BIG battery fast, just a bigger battery at home to sip off of. the best futuristic attempts are those that failed because some factor of their existence wasnt upto speed. this is a worthy concern when dealing with electric/altentative fuel vehicles. a bad "taste" from a failed young technology that tried to handle the "big boys problems and methods" will last and hamper the thing longer than it is actually an issue. without good "driving force" this "bad taste" can and often destroys technology. |
Originally Posted by marvin Yeah, but the quantity of hydrogen produced from nuke plants is nowhere near enough to meet demand if hydrogen fueled cars ever gain popularity. Current biological based methods are slow, and hydrogen generation through water splitting is very energy intensive. With current technology, we're stuck with cracking fossil fuels for hydrogen and or using steam reformation of natural gas. Both of these severely reduce the energy content of the fuel being processed. |
The other thing is that hydrogen sucks as fuel. The good part is that it burns clean. The bad part is that energy density is as bad as it gets. Liquid H2 has 1/4 the energy density of gasoline, and that number gets much smaller once you factor in the difference in containment system size. Sodium borohydride isn't much better. It gets rid of the containment system issues, but still only has 1/3 the energy density of gasoline. |
As for the fast charging idea, keeping a giant battery, even one that needs to be replaced as little as once a decade, is far more expensive than routing high current circuits to everyone's backyard. Not to mention that the high drain from quickly charging a car would be murder on battery lifespan. |
Originally Posted by nikongod you can always break water. just vent the oxygen, it will mix back with the hydrogen when you put it through a fuel cell that is prohibitively expensive for the crap output it gives. |
Originally Posted by nikongod it would probaly require a SIGNIFICANT expendature of energy to deliberately break any of these things into hydrogens... |
Originally Posted by nikongod alcohol, 1/2 the energy of gasolene, reneweable, while the plant of choice is growing it removes co2 from the air.... ooh, alcohol is a viable alternative to PRESENT PRODUCTION vehicles, and certanly e85. |
i dunno, if it were integrated into a home backup power suply, and a solar system it could woprk out to save you money. you could get sneaky and live in a state where you GET money for panneling your house (and buying necessary gear) which would include batteries. after that, a big enough pannel will put power into the grid, and you get money from the electrical company... |
Originally Posted by Ingo I wish I was a lobbyist for companies pushing Diesel engine technology. I noticed someone mentioned the new low-sulfur diesel that will hit the pumps next year. Diesel was already, in some regards, cleaner than gasoline. Now, I don't think there's even a contest. Things like soybean oil or any vegetable oil are easily burned in diesel engines with even fewer emissions. There is a company based out of Hawaii that does diesel engine conversions so they can run on pretty much anything. A kit for a Cummins 24 valve 5.9 Liter diesel (the diesel engine in Dodge trucks from 1998-2002) costs around $1500if you can install yourself. I think it's another $1000 installed. Anyhow, you can roll right up to a McDonald's, pump out some of their used fryer oil, strain it with a cloth filter, and put it straight in the truck. |
