PinkFloyd
- Jan 13, 2009
The DT-990 is a pretty hard phone to drive from all accounts so you may want to do two things:
1: Up the quiscient current by 20% this will give the amp a bit more grunt. To do this remove the four 10 ohm resistors (R7 & R8) and replace them with four 8 ohm resistors. If you do this ensure you fit heatsinks onto TR1 and TR2 as they will give off more heat which needs dissipated... having said that I've got my amp running with 8 ohm resistors in R7 & R8 and the transistors (TR1 & TR2) don't get too hot without sinks but to be on the safe side fit clip on heatsinks to TR1 & TR2 if they are not already fitted.
2: Up the gain to six. This will ensure that your comfortable listening level is dropped down from 12 o'clock to around 10 o'clock on the volume control. To adjust the gain to 6 remove the 3.3K resistors (R3) from both channels.. fit 4.7K resistors in their place and that will give you a gain of around six.
You can experiment with the gain and there are no rules written in stone, adjust it until you find a volume control setting your ears are comfortable with.
Gain is calculated thus:
G=(1+R3/R2)
In the stock guise:
R2 = 1K
R3 = 3.3K
So: 1 + 3.3 divided by 1 = 4.3 gain
Here's another example:
R2= 1K
R3 = 5K
So: 1 + 5 divided by 1 = 6 gain (1 plus 5K divided by 1K = 6)
Always calculate using 1 + the value of R3 and divide it by the value of R2 that will give you the gain.
Hope this helps.
All the best
Mike.
EDIT: My comfortable listening level with HD-600's is 9 o'clock postion if I went up to 12 o'clock it would be a lot louder.
Originally Posted by 1UP Thanks, Mike, yes that explanation really helps. Begs the following questions, though: is it possible to set a gain of 5 or 5.x? What clock-position is your volume knob when listening to rock music at a comfortably enjoyable volume level? I find I need to get to between 12 and 1 o'clock with my DT990s. |
G=(1+R3/R2)
In the stock guise:
R2 = 1K
R3 = 3.3K
R2= 1K
R3 = 5K
Hope this helps.
All the best
Mike.
