Mar 13, 2013 at 12:46 PM Thread Starter Post #1 of 11
crazy0023
Which are better the Monster Turbine Pro Copper Con HD and Micro In-ear Earphones or Monster Cable Turbine PRO High Performance Multilingual In-Ear Speakers - Copper?
Here are the links to the amazon page for both In ear headphones.
http://www.amazon.co.uk/gp/product/B002TUTMXK/ref=cm_cd_asin_lnk
http://www.amazon.co.uk/gp/aw/d/B003F5V11Y/ref=redir_mdp_mobile?qid=1363191301&ref_=sr_1_2&sr=8-2
THANKS
Mar 13, 2013 at 7:38 PM Post #3 of 11
Both crap. Assuming your budget is $150-200, get a Vsonic GR07 from LendMeUrEars.
Mar 13, 2013 at 7:42 PM Post #4 of 11
Well I have the dre beats mixr and I have a chance to swap them for Turbine Pro Copper Professional.
This is a link to the actual product:
http://www.monstercable.com/productdisplay.asp?pin=5734
Will I still not go ahead with the transaction? Thanks alot really appreciate the help.
Mar 13, 2013 at 9:58 PM Post #9 of 11
Thanks again for the reply. Yes I'm from the UK well I don't really have a budget, I brought some dre beats mixr a while back and now I have the opportunity to swap them for some monster turbine coppers hence the reason I'm asking are they any good and are they worth the swap?
Mar 13, 2013 at 10:24 PM Post #11 of 11
Thanks a lot for the sound advice since I've never really been a massive fan of IEM I prefer the over the ear feel, but i assumed the monster turbine were exceptionally good so they would blow me away and it would be worth switching to in ear which I'm not a big fan of, but I guess I was wrong.
