Originally posted by Magicthyse
If you can afford it, for the MP3/CD afficionado who doesn't have to record on the move, the iPod is in order of magnitudes superior to MD in terms of sound quality (with like-for-like audio material), ability to drive different headgear, versatility, speed and lots of other stuff. It's also not that much bigger than an MD. |
I'm a big iPod fan, but I disagree with this. Unless you're ripping MP3s at *very* high bitrates, and MD player in standard mode will sound better. ATRAC is simply a superior encoder to even the best MP3. The only way the iPod (or any other MP3 player) will sound better than standard MD is if you're listening to AIFFs/WAVs.
As for size, the current MD players are about 1/3 the size of an iPod
Do NOT go MD unless you're prepared to spend money on a high-speed dub system or deck, or if you do have a monster of a PC to use NetMD Simple Burner with. If you are prepared to do that, they ain't bad. [/B] |
I also don't agree with this as a hard rule. If you're the type that is contantly wanting to listen to different things, and you don't have the patience to copy in real-time, then I agree with the above. But a lot of people aren't; I've never had a problem with the fact that I have to record in real-time. I simply put a CD on and press play, then do something else (or *gasp* listen to the CD
). In return for being patient, I get better sound than MP3
Plus with an MD player you get MUCH longer battery life (mine has over 60 hours, and it's two years old), better "active" use (MD is much better than a hard drive for exercise), and smaller size (of course, with less music).
Personally, I think that for listening when you don't need a huge library of songs, MD is a better all-around platform. It's when you get into wanting thousands of songs that hard drive-based MP3 players really shine.
Just to be clear, I'm not dissing the iPod -- I plan on getting one
-- I'm just saying that the issue of MD vs. MP3 isn't as cut-and-dried as people usually portray it (x is better than y).
