Originally Posted by Gladcow /img/forum/go_quote.gif
but with a designated external DAC and a high quality audio file then that should be sufficient for any headphone right?
Yes, assuming that:
-the DAC can be connected to your computer (or other music repository) in some fashion (which may or may not require a soundcard)
-we're not talking about a DAC that's not designed to drive headphones (you'd need an amp)
-we're not talking about electrostats or other exotic headphones (you'd need a special amp designed to drive those)
Just in case you're confused about what a DAC is, it could mean:
-a component of most soundcards, DAPs, CDPs, and so forth
-a device that's dedicated to D/A conversion
-a product description for USB soundcards marketed to audiophiles
-probably something else too
Oh, and your DAC is your source unless you're using a turntable or some such.
All you need is a soundcard really because most models include a DAC and an headphone amp. Some cheap models such as the TBAAM are often recommended around here although most of us settle for fancier (and hopefully better) equipement.
