Which DAPs in 2020 have two Micro SD slots?
Sep 14, 2024 at 7:41 AM Post #33 of 38
In 2021 I got the Sony DMP-Z1 and I put 2x 1TB sandisk extreme. And today I have not had problems with some quality issues during playback of DSD256 or 24-bit/352.8kHz flac.
But I have a problem. Both cards are almost full. Since I hear last posted, my library grew immensely. Reaching now 1.75TB.
For my DAPs with a single slot i'm forvced to downsample in order to fit all my music in the new .5 TB micro as a card... to 16/44.1 or 48
For many years, I consider the problem mentioned by fiio what about mixing cars of different different rate and right spits like for example mixing a sandisk ultra and an extreme pro... therefore this problem never made sense to me as long as you use the two cart of the same type. But I read a post bulb that mentions something like master and slave figuration of the two slots and this makes some sense, but I think that could be also configured, and I don't think that it impact the quality of played sound.
By the way Sandisk we release the 2 TB microSD cards about at the end of September
Sep 14, 2024 at 8:37 AM Post #35 of 38
Sandisk make 2TB very affordable. Just a head up, make sure you store your collections in multiple HDD as they are easily recoverable. Unlike SDD, they are hardly recoverable, and the more capacity it has, the more it prone to errors and die out. You don't want to loose all of that
Sep 14, 2024 at 9:18 AM Post #36 of 38
Fascinating...at last! I'll bet they'll be pricey though.
There will be two versions of the 2 TB microSD cards. The extreme version will cost €279 and the extreme pro version will cost €329.
Sep 14, 2024 at 9:19 AM Post #37 of 38
I stored my music in three external hard drives. One has already failed on me so I quickly went to the shop and bought another one of higher capacity and quickly copy the data from the healthy hard drive and I mean hard drives not SSDS
Oct 8, 2024 at 4:26 PM Post #38 of 38
Laced order for two sandisk extreme pro microSD 2TB. Shipping until mid november
