dcstep
- Nov 27, 2007
I'm a serious, semi-pro trumpeter/guitarist using the Triple.fi 10 Pros to listen to classical, small group jazz, big band and some pop/rock. They're my secondary HPs, mainly for travel, but I DO use them at home also, through a Woo Audio WA6 single-ended tube amp playing mostly vinyl. They're wonderful, comparable to my AKG K701 full-sized in the mids with much more bass, but accurate bass.
I've been lucky to establish good fit with mine. I'm 6' tall and 200+ pounds, so I was surprised that I got the best fit with the smallest tips. I wonder what small people will do. Of course, good fit is critical with any IEM. If you have great drivers and a good fit, then the sound is very good.
Dave
Dave
