Uncle Erik
Uncle Exotic
- Mar 18, 2006
It may be more trouble than you're willing to go to, but I've had very good results with the Dickman Amp. It's not commercially available, but the schematic is found in issue #16 of Vacuum Tube Valley. Here's a link:
http://www.vacuumtube.com/
You can order backissues there. Dickman designed this amp specifically for Grados, which is why I decided to build one. All the parts are readily available and the cost runs $250-$300. More, if you use boutique parts.
If you don't do DIY, you can see if MisterX or any of the other builders will build one for you. You should be able to easily get one under $1,000.
