wallijonn
Throwin' tantra.
- Oct 15, 2002
tried the senn pads. imho, you're better served with the sock mod (see head-wize).
the reason why the bowls are uncomportable is because to get optimum sound the pad (at the rear) has to be over your earlobe. if you shift the pad back, so that it's not pushing in on your ear lobes, the pressure is somewhat alleviated. it'll be just a slight change in acoustics and soundstage.
i cut the holes in the senn pads. basically the pantyhose is now touching your earlobe and there's less pressure on the rear part of your earlobe. the soundstage changes because the angle of the transducers, due to less pressure, more closely follow the contours of your ears.
you can do better by going to a carpet place and buying $2 worth of 1" soft foam (about 2.5' x 1.5') and cut to whatever size you want.
actual shipping was $0.37 cents. anyone want free pads? they're, and it's, not even worth the postage.
