el_matt0
- Feb 7, 2007
guys, im getting Ken @ ALO to recable my ultrasone ED9 with some of his famous Jena Labs Cryo 18AWG copper. Now, while my plan was intially to just get it recabled to balanced dual XLRs, for use with my b22, I'd kind of like to have it terminated in a 4-pin XLR instead (as people do with K1Ks), and have 2 swappable "adapters", one with dual male XLRs for use with my b22, and the other with simply a 1/4" single ended connector.
Couple questions, for this purpose, people standarly use 4-pin XLR's right, or am I mistaken and is 5-pin the standard for this (I realize that technically this doesnt matter). Secondly, the wiring scheme for this should be super striaght forward right - if the 4 pin XLR corresponds to (L+,L-,R+,R-), then for the "balanced adapter", I'd want L+ running to XLR-L pin 2, L- running to XLR-L pin 3, and XLR-L pin 1 open. Same thing for the right XLR right, but with the R+/- signals obviously? And for the "single ended adapter", I'd simply just want L+ to go to the L (tip), R+ to go to the ring, and both L- and R- to the ground - correct? I'm pretty sure I'm right here, Ken just wanted a pinout wiring scheme, so I want to make sure Im 100% right on that.
Lastly, although I have yet to get official confirmation from Ken, I believe the grade of connectors he uses are Furutech XLR's and Furutech 1/4" connectors (correct me if I'm wrong here). He needs me to provide the 4 (or 5) pin XLR, so I'm wondering if you guys know of something that would be adequate for this quality of cable/connectors. I'm in Canada, so I'd be less inclined to order overseas, from the USA is fine obviously. Does Furutech even make a 4 or 5 pin XLR available for sale, I'm just thinking that using something like a Neutrik here might be a weak link in the chain and deplete the purpose of having higher grade connectors elsewhere on the recable! Any input is much appreciated here! Thanks all!
