jdandy
- Jan 29, 2011
dagothur.......The PS Audio Power Plant Premier A/C regenerators are capable of storing energy, and on demand delivering as much as 40 amps instantaneous peak current, so each PPP is quite capable of handling any gear powered by it. Actually, I could power my entire rack, including both power amps with a single PPP, but I chose to power the amps on their own dedicated 20 amp circuit, and the preamp and source components on their own 20 amp dedicated circuit. To make this happen required two Power Plant Premiers.
My first impression after installing the Power Plant Premiers was a darker, more black background. Silence is total blackness. From this silence music appears with wonderful detail, splendor and ease. I can hear deeper into recordings. As an example, sustained and decaying piano notes literally hang in the air until nothing is left but silence. I can hear lips parting, soft breaths taken, even occasionaly can actually hear taps of feet keeping time. The clean power produced by the PPP's also improved the space relationship between instruments, voices, bass, and drums. Any hint of smearing vanished. Feeding clean, perfectly regulated power at the proper voltage components are designed to operate on is the very best way to get all you paid for from audio equipment. It all starts with the quality of the AC power.
There are many power conditioners on the market from well respected manufacturers, but there are not many manufacturers making AC regenerators. I have used a few power conditioner products with my main system and the studio system, but none produced the sonic improvements like the Power Plant Premier. I have several friends who also use the Pure Power 2000 AC regenerator, and are quite happy with that component. Its largest difference from the Power Plant Premier is that it includes battery backup, so a temporary power glitch or short interruption in power does not shut down the audio system. This is not a feature that I felt I needed, but still represents an advantage over the Power Plant Premier if that feature interests you.
