What's wrong with my setup? Disappointing sound.
Mar 12, 2021 at 4:28 PM Thread Starter Post #1 of 55
krt230
USA
Hello,
I'd appreciate any help in identifying the weak link in my system because the music seems underwhelming and lackluster.
Computer playing Tidal
AudioQuest Carbon USB
Burson Audio DA-160 (10 years old? at this point)
AudioQuest Mackenzie RCA
SPL Phonitor XE
Danacable Lazuli
Focal Stellia
I can't figure out what's going on, but I feel like I shouldn't be disappointed with listening to music. Any suggestions?
Thanks for your help.
Mar 12, 2021 at 4:48 PM Post #2 of 55
There may be an issue in the chain somewhere. Could you explain the issue?
Mar 12, 2021 at 4:54 PM Post #3 of 55
It's hard to explain other than the music sounds lackluster. I'm not sure of the correct vocabulary but in a direct comparison, it's marginally better than bose headphones or aipods pro. I wouldn't think that was possible so I was hoping there was a glaring issue with my setup.
Mar 12, 2021 at 5:16 PM Post #4 of 55
Have you tried the Stellias in other DAC/AMP or in the shop before buying? Maybe you have to adjust to it's signature.
Mar 12, 2021 at 5:30 PM Post #5 of 55
I'm playing around with a new setup, playing on Tidal from my desktop. I got better results when activating "Exclusive mode" in Tidal. Chose your USB Dac from the speaker-icon in the bottom right corner. More settings --> Activate exclusive mode.
Don't know if it will help you, but it did help me.
Mar 12, 2021 at 5:36 PM Post #6 of 55
Hello,
SPL Phonitor XE
Danacable Lazuli
Focal Stellia
I was facing almost the same problem, and I did the following:
1. A specialist came to my house, measured my space and set up the speakers correctly. The upgrade I got was very big.
2. I paid close attention to the support of my machines, buying HRS platforms. Of course there are other companies.
3. Power supply. Dedicated line which will give power only to the machines.
These are the basics for a sound system to play properly.
Mar 12, 2021 at 6:09 PM Post #7 of 55
Wow, I can't believe it but this seems to have helped quite a bit.
Really appreciate the advice.
Mar 14, 2021 at 5:53 PM Post #13 of 55
Have you tried to listen to the exact same music in CD fashion? As a cross-reference you should try and swap-in a CD player.
Mar 14, 2021 at 6:49 PM Post #14 of 55
If you can hear the difference between the accursed Windows Audio and Exclusive mode, there is hope. :) Plenty of good gear listed there.
Just make sure you get the software setup correctly. If you don't have an MQA DAC then turn off MQA passthrough and let the desktop app unfold. Turn off auto volume and auto anything else you can find in other apps.
Are you sure the volume levels on your computer are at 100%? That’s the first thing that comes to mind when you said lackluster.
If exclusive mode is on then volume is fixed at 100%
