If it is easy to design a DAC yourself, and an Amp yourself, then you could do it right ?
If following DIY published by others were easy, then you could do it right ?
I kindly ask any of you enthusiasts to rethink the values of these products. They are small scales and they are uniques. They were never about the money. However, I don’t think it is going to be easy for everyone and the mass consumers to understand the price point either.
I myself , DIY a lot of things, and to properly built a high end DAC/Amplifier, the materials are not cheap, the chassis are not cheap, even the jacks and plugs, wires can’t be cheap, the beautiful chassis are not cheap either. Then the unique headphones that if you try and DIY, are not cheap. There are enough recipes and blueprints to attempt a DIY your own E-stat, DAC/amp, you are welcome to try, and before you realize that, you are probably be dwelling into the 20-30k ranges (this is with other engineers schematics and designs). Then another 20k is probably to support a company running as paying the engineers, the logistics…customer services…etc…
