kobegibson
- Apr 30, 2011
I feel FLAC as a 5*3 retangle and APE a 4*4 square. I love APE more.
In which way??
In the way that music plays.
FLAC's sound is very solid and near. Like you are in a house of 5*3 feet, 5 horizentally and 3 vertically.
APE's sound is not as solid but it is deeper.
It's like the difference between Koss Prota Pro and AKG K450.
Both are lossless formats. If played back on the same equipment, they should sound exactly the same. The only reason why one may sound different from the other is if you're using a crappy decoder that distorts the sound when decoding it.
From what I understand, though, APE files are very hard on the decoder since it uses a symmetrical encoding system - that is, it takes the same amount of processing power to decode as it does to transcode.
If I may ask, what equipment did you use to come to this result?
Anyways, how do you play lossless files?
Yeah! A psychological thing, that's reasonable.
We Chinese are very good at "placebo", you know, we use to believe Mao Tse-tung is the god.
Same thing happened there in Germany,huh, monoethylene
I must say, after being in China for awhile, the placebo effect is put to great use here. Since it seems that everyone believes fully that things like sea cucumbers and fungus worms are supremely good for their health and well-being, which I honestly kind of doubt.
I can tell you that history of Chinese medicine is much greater in age than Western medicine. Medicine is an art right now...
