I would add the Ananda BT. I haven't heard it, but I do own the Ananda and they sound great.Sennheiser, Bose, Apple or another brand?
What's Best Wireless Headphones If Money Is No Object?
- Thread starter hankypanky2
Chamade
I would add that the Ananda BT is in a different universe when it comes to sound quality, compared to any of those mainstream closed back ANC cans.
jagwap
You may be right that these are the best.I would add the Ananda BT. I haven't heard it, but I do own the Ananda and they sound great.
But most wireless solutions are sought for out and about use, so a closed design is needed. If that is the case then the Dali IO-6, Audeze Mobius and B&O H95 should be on any short list. I have the last two, and while the Mobius has the edge, it is too fragile for mobile use. I'm on my second par and they are creaking in an alarming way like their predecessor. H95 is a leap better than the others in B&O's range, and most importantly: Musical.
AKG make some good stuff, and K371BT is an absolute bargin (the wired version is better naturally). Not in "BEST" category, but surprisingly good.
Bose are too tame/safe, and Sony, Sennheiser & B&W are way too bass heavy to be considered serious headphones.
