Originally Posted by ssportclay
What make and model of tonearm could I mount on my Thorens TD-160 that would give me the capability of blowing a VPI Scout out of the water?
Steve is absolutely right that there havn't been that many technical advances in turntables since the 1980's. Conventional wisdom is that where things have moved on is in the use of various plastic composite materials for platters, instead of wood and steel to damp resonances and that there have been major advances in Tonearms and Cartridges.
The VPI Scout looks like a very nice state-of-the-art deck, employing a unipivot tonearm and a wood composite plinth.
Look a bit closer though and there arn't that many things about it that are so new. Unipivot tonarms were fashionable in the 1960's-70's when the vogue was for low mass. This design philosophy was all but swept away by the likes of the Linn Ittok, Alphason HR100 and Rega RB250 in the 1980's which unsurprsingly sounded better on the Linn LP12. Only the Naim Aro continuing research into unipivots.
There is a famous British Tonearm called the Hadcock which has been made since the 50's almost unchanged and is now again very much in vogue due to the trend away from suspended subchassis. What goes around comes around in Hi-Fi as well....
http://www.tnt-audio.com/sorgenti/hadcock242_e.html
A much cheaper even older design that's still available is the Decca International which is many people's choice for the Lenco derived decks.
I have yet to experiment with unipivots but by all accounts they sound very fast and musical in the midrange but lighter at the frequency extremes.
For the rest the VPI looks like a conventional belt drive made out of woodchip with an acrylic platter. Not a whole lot different to a Rega Planar 3 for which acylic platters have been available for a while.
The Thorens TD160 is a classic design. I had one for a while and it's got a very springy suspension which needs careful levelling but really makes the music bounce along. It's amazing with percusion and very much in the style of a Linn Sondek with which it shares the same design heritage. I tried it with SME 3009 Series 2 and 3 and with Linn LVX tonearms.
It's main failings are in the lightness of construction in the plinth which make it sound a bit lightweight compared to my Thorens TD125 or a Linn Sondek. I wouldn't underestimate the TD160 though, it really is a capivating deck that makes you want to just listen to all your records which after all is it's purpose!
I prefer this over the Rega style which can sound a bit dour and grey hence the resurging fashion for unipivots to inject a bit of liveliness perhaps...
I would certainly go for upgrading it. Check out
http://www.hi-fiworld.co.uk/hfw/olde...renstd150.html
Since this has been written there are a lot of small firms springing up on Ebay supplying bespoke new parts. Get a heavy wooden plinth in Oak or build one yourself. This will give it a much more solid foundation and work wonders foir the base. Also fit a Silicon platter matt which gives a much better focus to the sound.
Check out
http://cgi.ebay.com/ws/eBayISAPI.dll...787814008&rd=1
This guy also makes arm mounts for Linn / Rega and SME tonearms. I think the Linn LVX does go very well. You should be able to pick this up for 200USD 2nd hand and it will make a huge difference over the stock Thorens one. Mine came with the classic SME 3009 (another 50's design) which is great for classical and Jazz but doesn't really cut it with Hip Hop.
If you listen to modern music then the Rega RB250 is the most popular arm simply because it offers amazing value for money and outclasses most arms under 2000 dollars with a few tweaks. A lot of people say it doesn't work so well on suspended subcassis decks like the Thorens but I'm running the OL modded version on my TD125 and it sounds very good. The TD125 has a less spingy suspension but with careful levelling and on a solid shelf isolated from vibrations it should be fine.
A Thorens TD160 in modded form will take on anything new or old into the thousands of dollars. It's a very special deck. I wouldn't trade it in for anything less than a Linn Sondek, Thorens TD125, Michel Gyrodek, Technics SP10, Garrard 401... etc and you are talking serious bucks...
