- Jan 30, 2011
Hi Dan
I know Amos already answered you - but I wanted to reply personally. I hope you don't mind.
I originally started volume matching with everything I was reviewing a little over a year ago. I did this after watching Ethan Winer's Audio Myths video (and one or two others), and realising that my reviewing style (while becoming popular) wasn't as accurate as it could be. In short - my contributions weren't doing justice to anyone - the manufacturers, the readers, or myself.
So I initially started - simply using an iPhone app. it was better than using nothing at all - but as you found out recently, it was still not accurate enough. So I then bought an SPL meter (according to the documentation it has been properly calibrated), and it will measure to within 0.1 dB both A & C weighted. I now use it on all my reviews when making comparisons. I probably should make more of a point of mentioning the methodology I use when making comparisons. Thanks for pointing it out.
Actually - you'd be surprised. There are a few of us now. Some are still using apps (smartphones) - others like myself, earfonia, and baycode all use SPL meters. The more people who notice it (and who want their own reviews to become more meaningful), the more eventually will adopt it. It is time consuming, takes a lot of checking and rechecking - but I do think it is worth it.
Yep - I told you about that. And I also told you to treat it as a subjective review - all of mine are. I try to remove as much bias as I can - and I try to inform the reader in advance of any known bias I have. It is all very simply to make sure that I can give a reader of my reviews a base line in which to interpret what I've written.
I know you have very strong views on the X3ii. That's OK - but you also need to take into account that:
[a] You did not volume match as accurate as possible
Your tests were also sighted
[c] You also have expectation bias - we all do - we can't escape it.
Now I'm not saying my views are any more relevant than yours. It is my subjective opinion. You talk about a wide difference between X5 and X3ii and you seem (to me anyway) to be saying that if anyone disagrees with you, they must be wrong. Just as a thought - how about considering that we may have different preferences? I agree that there is a difference between the X3ii and X5. My tests showed that comparatively it was pretty close (to me). X5 was flatter, smoother, blacker background. Jazz actually prefers the X3ii to the X5. Others say different again. This is where preference comes into play. There is no right or wrong. You seem to be on a crusade saying you an't trust any reviewers because our opinions don't exactly match yours. I've got news for you my friend - most reviews won't - because we have different subjective preferences
Anyway - hopefully you find a reviewer you can follow. I always follow the same two or three when I need advice on audio equipment - they have similar tastes to me and I generally feel their reviews match my preferences - that is the secret I think.
As to my methodology.
I hope this helps a little. My method is not perfect. My reviews will ultimately always have subjective bias. But I'm actually pretty content on what I put out there nowadays. Judging from a lot of the reactions from others - they're happy enough with the content. But I'm always open to suggestions within reason.
Last thing to note - I review because I enjoy doing it. I don't do it for free gear (I offer to return all the gear I'm reviewing - ask any manufacturer I deal with), and other times I buy the gear. I actually don't even do it for the public here. I ultimately do it for me - because it is a hobby I love, and the review process helps me learn about my own preferences.
Sorry for the long post.
Take a look at the reviews for the X5 and X3II or any of the headphones on head fi. How many are volume matched? That's right. None.
I should add that even a volume matched comparison is not valid.
Brooko openly admits that he EXPECTED the X5Ii to sound better even before testing.
So, even with volume matching, the testing must be double blind with neither the test admistrator nor listener knowing which source was which during the testing itself.
So, Brooko could very well have been influenced by confirmation bias, which he readily acknowledges is a distinct possibility.
The bottom line is that there is no such thing as a valid comparison here on head fi. Only volume matched double blind testing results are valid, and while I can't say they don't exist on head fi, I can assume they are very rare.
- I always use an SPL meter now - both for comparisons, and also making my own frequency response charts (crude but seem to be effective)
- I match volume using set tones - usually @ 1 kHz. Some have recommended pink noise - but I usually choose similar headphones when comparing - so I find my current method pretty effective.
- I have a two way switch when comparing DAPs. I volume match before they go on the switch and again during and after. All EQ is disabled. I use exactly the same files on both DAPs and always the same headphones. Each headphone used is volume matched. I then set-up the playing so that both DAPs are playing the same playlist virtually simultaneously. I can then flick backwards and forwards.
- Where possible I get my wife or daughter to assist with the switching, and I always close my eyes while they are doing it. If They aren't around (or I can't coax them into it), I just use the switch myself, eyes closed, and very often I completely lose track of which DAP is which until I open my eyes. The pun here is that often this has been an eye opener. You should actually try this at some stage. You might find those current "night and day" differences fade to more of a twilight
