WHAT KIND OF ADC DAC PC Audio device is this?
Jan 16, 2013 at 6:48 PM Thread Starter Post #1 of 20
Radioboy86
It was labled as a Pinnacle/Steinberg ADC PC Audio converter? Does anybody know about this device? It has the LABEL numbers/Letters "PPA-1" any help would be appreciated thanks
It looks like a USB type device? I have checked all sites and no info has tuened up.
Jan 16, 2013 at 7:00 PM Post #2 of 20
Guess it takes in an analog audio signal (3.5mm or RCA) and uses the ADC (Analog to Digital Converter) to change it the analog audio signal into a digital audio signal, then outputs that digital signal thru the USB output.
Can you take more pictures from different sides (larger pictures), cause I'm taking a wide guess on what it is.
Jan 16, 2013 at 7:40 PM Post #6 of 20
I HAVE FOUND NO OTHER IMAGES... IT MUST BE RARE AND UNKOWN. I HAVE SEARCHED FOR HOURS
So you do not own one and your not sure what it is?
So why waste time with it?
Jan 17, 2013 at 2:06 AM Post #8 of 20
It looks like gold spray painted plastic... It might be a scam, especially with no other pictures from anywhere...
Jan 17, 2013 at 2:10 AM Post #10 of 20
No its real. Its just something uncommon. i think it went with other hardware and software. i guess ill find out soon enough, for 15 Dollars ill take the risk
Well, tell us how you like it! :D
Jan 17, 2013 at 2:12 AM Post #11 of 20
Bought it for 15 dollars. it seemed like a steal if its got the Steinberg/Pinnacle name
So you do have it, but do not own anything (camera or cell phone) that can take more digital pictures of it?
Jan 17, 2013 at 2:13 AM Post #12 of 20
Jan 17, 2013 at 3:58 AM Post #13 of 20
From my searching, it appears to be be an outdate analog USB recorder, which if you're lucky will work as a generic USB device, but likely will require drivers, which probably only exist on media that was original with the device. It has been long since discontinued and neither Pinnacle nor Steinberg support it.
Jan 19, 2013 at 2:56 AM Post #15 of 20
http://www.ebay.co.uk/itm/130779862888
Was all I could find, but I've seen similar products throughout the years. I would have put the $15 towards Fiio or cables.
