- Separate high quality DAC's for L & R channels
- Improved jitter correction
- Higher quality Clock generators
- EMI/RFI shielding
- Possible Balanced output such as XLR
- Different output section TRS, TS
- Improved output sections using higher quality components
- Different daughter cards allows specific features.
Some cards actually already have at least some of these features--my 1212m has a few, and it made a pretty outstanding difference from my onboard Realtek audio.
Part of the problem (or perceived problem) is once you put a pci card in a computer, it really becomes a part of a larger system, both hardware- and software-wise. As many people have mentioned, a $3,000 external DAC and an onboard card could have the same DAC chip (or chips), but differ greatly in the supporting componentry and implementation.
So, following this logic, I think you need to look at more than the card itself, but the supporting MB, power supply, Operating System and installed software components.
I've been wondering myself: Some cards like the Essence STX pull their power right off the power supply, skipping the power running through the PCI bus. But I got to thinking, couldn't you make some improvement to your computer source just by upgrading to a better PSU for the whole computer? And why wouldn't you, considering better componentry on this side might translate into better stability/performance for your computer source in general?
People spend a lot of time debating about power supply cables for their outboard gear, but what about that cheap wiring to the MB main and the Molex connectors that's ubiquitous in the industry today? I'd be interested in seeing what, if any improvement you might see if someone improved their PSU unit (I've been looking at some of the quiet units by Seasonic myself), and modded their own power supply cables for the internals inside the computer case. *If* there's any issues with EMI/EFI (which some say is debatable), it seems you could make some notable improvements in this area by working on the problem closer to at least one of the sources, I would think.
I know this is a bit broader, perhaps, than your interest in improving soundcards, specifically. To come to a point, I guess my thought is there are a number of soundcards out there that are already pretty darned good, and it doesn't make a lot of sense improving them much more until we look at improving what we're plugging them in to.
Some very theoretical musings, I'm afraid, but you started a very theoretical thread. I'm very interested in hearing some other people's comments.
