...Then, a little later still, I got into some loudspeaker research, and found myself called upon one day to make a research recording, wherein I recorded a batch of clicks with very carefully documented changes in level between the stereo channels.
This was one of those cases where I figured I knew what was going to happen before I started.
Given my golden ears, there just wasn’t much doubt that I could hear the image move as soon as I tweaked the pan-pot even a little, so I decided to calibrate the changes to 1/10th of a decibel, so that I’d be able to really pick out the subtle differences in localization that were going to happen when the levels between channels changed.
However, I was very startled to discover that the phantom image didn’t seem to move at all even when the levels between channels changed a whole decibel! I was so startled that I became positive I had made a mistake when preparing the tape!
A little investigation (well, about three hours, including chasing down all the wiring in the monitoring system!) showed me that I hadn’t made a mistake, and when the dust finally settled I had found out something quite interesting: that as long as the difference between channels is less than 3 decibels, the phantom image hovers pretty much in the middle point between the two speakers.
I promptly ran this down to my buddies at the local loudspeaker factory and we tried it in the anechoic chamber with blindfolds and people pointing at the imaginary phantom, and it still remained true: with up to 3 dB difference between channels (that’s half-power, remember!) the image didn’t move much, maybe five degrees.
With between 3 and 6 decibels difference in levels, the phantom quickly and without much stability migrated to the louder speaker, hovering just inboard of that speaker, and once the difference was greater than 7 decibels, the phantom was for all intents and purposes coming from the louder speaker.
