Originally Posted by Trogdor
Hey Ray, thanks. Technical question for you if you don't mind (to Tyll as well). Is the purpose of using a tube gain stage to introduce some of the benefits of second harmonic distortion cleaner? i.e. why would you do this at the gain stage instead of the output stage?
I REALLY REALLY appreciate all of the feedback guys!
Tubes are wonderful for thier ability to impart euphonic 2nd harmonic distortion, but when used as an output stage they tend to be very finiky about the impedance of the load. You know, I'm sure, that tube amps tend to synergize, or not, depending on the headphones you plug into them. This is largely because tube output stages have a relatively high and reactive (meaning has large inductive or capacitive properties) output impedance. This characteristic makes their sound somewhat "load dependant. So while you can get "euphony" from a tube output, it's character varies from can to can.
If a designer want a specific sound from the tubes, but also want to get that sound independant upon what headphones they are driving, one solution would be to voice the input stage with tubes, but deliver the output through a low-distortion SS output. A SS output stage can be built with a very low and largely resistive output impedance so that it drives most headphones without being effected by their impedance characteristics, and it high linearity and low distortion is quite capable of passing the euphonically distorted signal from the tube section with out imparting too much additional distortion of its own (purists will want to add here that there will be some). That way the voicing of the tube stage can be delivered to a wider variety of cans.
As to the "Marketing Speak" nature of the word "Hybrid". While many of these term makes me wretch ("digital ready" being my favorite example of horse manure from marketers) I don't think this term falls into that catagory. It seems to me, first of all, that the term "hybrid" is likely to have mostly a negative connotation to audiophiles. But more importantly, when a company descides to build a hybrid amp, they couldn't legitimately call it simple a "tube amp" or "SS Amp" as that would be missleading. As a marketer and copy writer, I can tell you that efficiency of copy is extremely important---I often struggle to keep the word count of ad and web copy to a minimum. Using the term "hybrid" allows marketers to efficiently describe a design that has both tube and SS topologies. So I don't buy your impression that the term is either missleading or intentionally adds percieved value to the product. In fact, it probaly brings up more questions than it addresses. But sometimes you have only the space for 10 or 20 words to describe a product, so it seems to me not much different than the term "Single Ended", "Balanced", or "Class A" as all of these do not describe circuit designs with a unique topology. "Class A" may be the biggest offender here, and probably borders on marketing-speak to a much higher degree than "hybrid" as "class-A" is known to be a term with a very high attraction rating for audiophiles.
