- Jan 9, 2003
Why? each driver has a + and - terminal to connect to both the signal and its inverse. What else is needed for balanced operation?
Originally Posted by wali The Cardas balanced cable for HD650 uses two XLR connectors but on the driver end it uses the regular unbalanced Sennheiser plugs... Now you don't need to be an EE to understand that you can't freaking transmit a 'balanced' signal using 'two' connector jacks. All the talk of noise canceling and other stuff is useless here because Sennheiser HD650 has only an unbalanced input (show me one headphone with balanced inputs). End of discussion for those who believe in common sense. |
