shineonyou
- Jan 9, 2015
McINTOSH MPH1000 ![Wink :wink: :wink:](https://cdn.head-fi.org/e/people/wink.svg)
As far as headphones are concerned, buy whatever you like the sound of. Spend under a hundred bucks on interconnects from a non retail company - look for someone that makes good quality no frills cables. Don't buy an after market power cable. Go for solid state over tubes because they produce less distortion, don't wear, don't need warming up and generally cost less for comparable specs. You only need to spend XXX on an amp in relation to your headphones otherwise you probably won't hear any improvement due to XXX. Single ended amps perform the same as the balanced equivalent. Stock headphone cables are fine. Cheap DACs are fine. Your DAC in your device will probably be suitable but if you want a desktop dac just get something like XXX or XXX otherwise you're spending money for no reason. etc etc etc. NOT NECESSARILY THAT ANSWER, but something along those lines with a few suggestions of what measures really well and punches above it's weight technically speaking. I didn't think I was asking anything difficult.
Ahh it wasn't necessarily about a DAC in the beginning. I was mostly annoyed about the amount of things we're told are just marketing or we're only hearing things because were told etc but a distinct lack of suggestions on what wasn't ********. I have read a few people saying my question doesn't make sense or they don't understand it - maybe I can't articulate things as well as some. HONESTLY, I didn't think it was a hard question. I was roughly expecting an answer along the following lines:
The DAC in the computer is as good as any?
MA - Whilst I may be in the market for a DAC upgrade later in the year (depending on how my audition goes), this specific thread is not necessarily about what dac I should get but more about people writing off products and not being able to name any alternative.
OBVIOUSLY the general advice is to listen to stuff before you buy it but here's the thing - I bought a v281 amplifier (after auditioning). I was concerned about the high price and the salesman said well you could get the v220 which is cheaper but just has 2 amplifiers identical to the four in the v281 so you just lose your balanced output - everything else is exactly the same. But I bought the balanced v281 instead of the single ended v220 because I thought it sounded better out of the balanced output than the single ended. Now, if I go and recommend to someone go and buy the balanced version of this amplifier instead of the single ended version of exactly the same thing because it sounds better, I would get slammed and told no, you're wrong, because according to SCIENCE, you are wrong. But then you turn around and say but the science doesn't matter because it's about subjective enjoyment. The two sides couldn't be more contradictory, yet somehow people seem to be on both sides at the same time. It's nuts - besides understanding how things work, is there any point whatsoever even discussing anything objective? Maybe if you knew the frequency response curves of a dozen headphones and could pick similarities between cans that you do and don't like, you could make an educated guess on weather or not you'll like a new headphone based on it's curve, but that's about the only example I could think of.
I just think it's nuts that you can steer people away from a million different things but not toward a single one. I KNOW, I know, subjective enjoyment. Yes, yes. But just do one thing for me - name ONE dac that is good and worth the money as far as measurements go. That's all I've been asking for this whole time. I don't know why people can ask you a thousand technical questions and you can answer every one, but recommend a product based on the answers to those exact same technical questions? No chance. Insane.
Ok, if you just want me to toss something out, Schiit Modi 2, $99.
Ok, so I'm aware of all the standard advice on what I should buy in the head fi market - get yourself a pair of HD800s or LCD3s or something. Maybe an Abyss or 009 budget permitting etc etc.
But I've noticed that the science forum is full of stuff that I shouldn't buy, and what is a con or just marketing etc. Don't buy expensive cables, don't bother with balanced, forget about tubes, the list goes on. So I was just wondering, what SHOULD I get??
If there's no difference between, say, a well designed $300 dac and a $5000 one, and no reason to go balanced, what could I buy that will sound just as good as Joe Blow's system that has all the bells and whistles but cost $35k? Should I be steering clear of electrostats for example or should I ONLY be looking at electrostats...I don't know. Assume I can afford anything on the market but don't want to be wasteful.
So as far as a purely scientifically focused mind is concerned, what is the best objective system I can buy for my dollar?
This thread is hilarious. Any native speaker knew exactly what was being asked in the first post, but the answer has been danced around at length by people that don't want to provide one. It's also frustrating, as it really isn't far from one that I had planned to start, but instead of a hypothetical, it was going to be more like, "What do the people of the sound science forum use when they walk out the door?"
That is, to those that understand the level of B.S. that goes in to selling audio gear, what actually gets your money? Just whatever cell phone you have with some easy to drive but decent cans? That's my guess for most of the portable rigs in this part of the forum.
Feel free to answer the OP question.
Because i can't. And i'm not a native speaker either.
What setup do you think is the best objective system money can buy, that sound as good as somebody else's five figure setup?
What actually gets one's money is a simple question.
Me, what actually gets my money is a magni 2 uber because, again, it's cheap. What I want is a woo audio 7 Fireflies. why? because it looks cool.
does woo audio 7 fireflies sounds different with magni 2 uber? From a hobby standpoint, yes. For 90-something percent of people in this world, not exactly, no.
Measurement wise, i know how odac and o2 sounds, and it sounds the same with schiit stack, so i just get the magni 2 because i want to.
I got the Magni 2 as well because even with the Modi 2 Uber it's slightly cheaper than the O2/ODAC, and they look prettier. The Woo Fireflies will give a warmer sound (tube amps), I would get it as well for a more musical and laid back listening experience if it was around $350. Sadly, it's over 2x more than I want to pay for a DAC/amp combo.
I think the most appreciable difference other than headphone is the absence of noisy hisses when using external DAC. On a $300~$400 cheap laptop, sometimes the dac / amp section is so bad it hisses, and the hiss is very noisy. Owning any dac/amps will fix that immediately, and very noticeably.
