mulder01
- Jan 13, 2012
A good set of cans, a good laptop, good recordings, and possibly an amp depending on the cans.
The DAC in the computer is as good as any?
That's the thing, though. Many of our recommendations are going to be based on measured differences. Subjectivity has to come in somewhere because one thing will sound more "right" than another. You aren't going to get agreement on a "perfect setup" because there will be measured differences in the drivers, and different drivers will play differently with different amps, and all of that has to be targeted to the individual. What do you like as a listener?I disagree that it's a loaded question. I know that technically speaking there are many products that achieve no measurable benefit and everyone is happy to point those out. I'm just asking recommend SOMETHING that performs at the peak of what we are able to hear, without being a gimmick that wastes my money. I legitimately want to know.
But what you've just said nullifies every reason to even think about the science behind behind this stuff and makes all measurements completely void of any purpose when purchasing gear.
If the only reason to buy something is because it gives me the most subjective enjoyment, then all measurements associated with that product are irrelevant, because I liked it the best.
And I know that's not what you think because if someone came along and said I just bought a $1000 interconnect and it makes my system sound so much better and I think everyone should buy one because my system has completely opened up and I can't believe my ears, you would tear shreds off them, not say "well if it makes you happy then yes I can recommend buying that cable"
It's not what this is about. I just see in this forum that there tons of products that are - according to science - a waste of time. Ok fine, name me one product that isn't a waste of time - that's all I'm asking. If I bought a regular from the sound science forum with me to a headphone store, what would he tell me to buy. It's not a trick question.
Ok, so I'm aware of all the standard advice on what I should buy in the head fi market - get yourself a pair of HD800s or LCD3s or something. Maybe an Abyss or 009 budget permitting etc etc.
But I've noticed that the science forum is full of stuff that I shouldn't buy, and what is a con or just marketing etc. Don't buy expensive cables, don't bother with balanced, forget about tubes, the list goes on. So I was just wondering, what SHOULD I get??
If there's no difference between, say, a well designed $300 dac and a $5000 one, and no reason to go balanced, what could I buy that will sound just as good as Joe Blow's system that has all the bells and whistles but cost $35k? Should I be steering clear of electrostats for example or should I ONLY be looking at electrostats...I don't know. Assume I can afford anything on the market but don't want to be wasteful.
So as far as a purely scientifically focused mind is concerned, what is the best objective system I can buy for my dollar?
I can just imagine taking someone with all this knowledge to a headphone store with me and saying
me: 'look - balanced headphones'
them: 'no - that's pointless'
'ok well look at this fancy $15,000 dac'
'nah they're a waste of time'
'cool looking tube amps?'
'all they do is look cool'
and then frustrated after the 10th thing that's just a gimmick turn around and say 'well what IS good then?' and they just don't say a word and walk back out the front door. Seems stupid to me to ONLY be able to bag out products based on their knowledge but not be able to make a single recommendation based on their knowledge.
MA - Whilst I may be in the market for a DAC upgrade later in the year (depending on how my audition goes), this specific thread is not necessarily about what dac I should get but more about people writing off products and not being able to name any alternative.
OBVIOUSLY the general advice is to listen to stuff before you buy it but here's the thing - I bought a v281 amplifier (after auditioning). I was concerned about the high price and the salesman said well you could get the v220 which is cheaper but just has 2 amplifiers identical to the four in the v281 so you just lose your balanced output - everything else is exactly the same. But I bought the balanced v281 instead of the single ended v220 because I thought it sounded better out of the balanced output than the single ended. Now, if I go and recommend to someone go and buy the balanced version of this amplifier instead of the single ended version of exactly the same thing because it sounds better, I would get slammed and told no, you're wrong, because according to SCIENCE, you are wrong. But then you turn around and say but the science doesn't matter because it's about subjective enjoyment. The two sides couldn't be more contradictory, yet somehow people seem to be on both sides at the same time. It's nuts - besides understanding how things work, is there any point whatsoever even discussing anything objective? Maybe if you knew the frequency response curves of a dozen headphones and could pick similarities between cans that you do and don't like, you could make an educated guess on weather or not you'll like a new headphone based on it's curve, but that's about the only example I could think of.
...I would get slammed and told no, you're wrong, because according to SCIENCE, you are wrong.
Here are some resources with headphone measurements:
http://www.innerfidelity.com/headphone-data-sheet-downloads
http://en.goldenears.net/GR_Headphones
https://docs.google.com/presentation/d/1wi8M-HSeK0JF33P-5ypydQjQ4OshRQhvWM0IX2h0NQ8/edit?pli=1#slide=id.p
http://www.head-fi.org/t/492673/complete-list-headphone-measurement-websites
You can listen to recordings of headphones here:
http://www.sonicsense.com/resourcecenter/browse/headphones.html
just think it's nuts that you can steer people away from a million different things but not toward a single one.
I KNOW, I know, subjective enjoyment. Yes, yes. But just do one thing for me - name ONE dac that is good and worth the money as far as measurements go. That's all I've been asking for this whole time.
I don't know why people can ask you a thousand technical questions and you can answer every one, but recommend a product based on the answers to those exact same technical questions? No chance. Insane.
I just think it's nuts that you can steer people away from a million different things but not toward a single one. I KNOW, I know, subjective enjoyment. Yes, yes. But just do one thing for me - name ONE dac that is good and worth the money as far as measurements go. That's all I've been asking for this whole time. I don't know why people can ask you a thousand technical questions and you can answer every one, but recommend a product based on the answers to those exact same technical questions? No chance. Insane.
