charlesE
- Apr 21, 2008
Maybe the experiment in the Banjamin and Gannon paper you mentioned had jitter injected into a DAC pre-PLL, i.e. on the line and not the sampling clock?
Originally Posted by charlesE /img/forum/go_quote.gif Interesting stuff, one thing doesn't seem to add up though (or maybe I'm just missing something). Figure 9 of this AES article: http://www.google.com/url?sa=t&ct=re...A_DAC-swN1Id-g Seems to indicate that Deterministic Jitter (sinusoidal) above 3kHz is audible at amplitudes of less than 100ps. The article states in section 3.3 "This plot can be used as a specification for allowable sampling jitter in Nyquist sampled systems. At 20 kHz the peak to peak sampling jitter must be less than 20 ps, increasing at 6dB per octave for lower frequencies until approximately 500 Hz where the limit is 1 ns. Below 200 Hz the jitter may up to 500 ns in amplitude before the sidebands could become audible." It references the article "Considerations for Interfacing Digital Audio Equipment to the Standards AES-3, AES-5, AES-11" also by Dunn's as a source but those values are off by about 3 orders of magnitude from the other figures that you quoted. |
Originally Posted by bigshot /img/forum/go_quote.gif Nick Charles, it's good to do all the groundwork on this, but you might want to sum up the information more often. Most people don't cross reference separate posts well, so your context risks getting lost in the shuffle. The average person looks at a bunch of numbers and science and assumes it adds up to something very important. It would be good to sum up frequently in layman's terms. See ya Steve |
Originally Posted by regal /img/forum/go_quote.gif Solen, Jitter is the least important feature of a DAC. The DAC chip itself and the analog section make the sound. To say that jitter isn't important does not in any way shape or form mean that the rest of the DAC adds no value. Your statement just personifies the ignorant path we have been led down by the experts in the last several years. The choice of DAC chip and analog circuitry used has a HUGE impact on the sound. |
Originally Posted by Solan /img/forum/go_quote.gif I know. Slightly tongue-in cheek, since I'm not exactly buying a $50 DAC myself. But what I've noticed is that the big selling points for the multiple kilodollar DACs feature "jitter" rather prominently. So the returns may be not just diminishing, but non-existant, if you pay $1000 to get rid of that last bit of jitter. |
Originally Posted by Solan /img/forum/go_quote.gif What about recordings that vary sound levels a lot, from mellow and almost quiet to full burst. Orff's Carmina Burana is an excellent example. At the high end of the dynamic range, no jitter may be heard since the dB difference between music and jitter is so large, but when the choir is barely mumbling, this dB difference is far smaller and jitter may be audible, again justifying the need for some care when evaluating jitter's impact. |
Jitter induced by the digital audio interface was not found to be an audible problem for any of the program material auditioned. |
Originally Posted by bigshot /img/forum/go_quote.gif Actually, I meant translating all the numbers and science into something that might help a 21 year old kid decide whether to drop a paycheck or two on buying high end audio equipment to reduce jitter in his system... Most people reading here don't have any idea what a nanosecond is or what a distortion sideband sounds like. You've done a great job of chasing down all the particulars, but unless that is put into the context of a real world practical application, it isn't going to help anyone. Say I'm living in a dorm, and I have a $300 Dennon CD player, a headphone amp and a nice pair of Grados or Senns... What impact would attempts to reduce jitter in that sort of system have on the sound? Would an external DAC improve the jitter levels to a more acceptable level? Would connecting it with USB sound better because it has less jitter than optical? Do I need to reclock to get better sound? These are the sorts of questions most people here have about jitter. A listing of the technical specifications of jitter, no matter how accurate or precise doesn't really begin to answer those sorts of questions. You need to give more context to the data. Your quote about jitter's effects on various types of music from Benjamin and Gannon above is a great start. Now sum up the context of all that science when it comes to typical home audio equipment. Not criticizing... just suggesting. See ya Steve |
Originally Posted by nick_charles /img/forum/go_quote.gif In short As far as I know there is no reliable i.e carefully proctored experimental evidence to suggest that any currently available commercial digital audio device has any form of jitter at a sufficient level likely to cause empirically audible degradation in music played at normal to loud listening volume. Jitter added by coax or optical cables or by the addition of external DAC devices does not appear to be at a sufficient level to be problematic. EDIT: I did not see Tim's answer when I posted this, but on a purely personal level I concur with his assessment. |
Originally Posted by nick_charles Jitter added by coax or optical cables or by the addition of external DAC devices does not appear to be at a sufficient level to be problematic. |
Originally Posted by Pars /img/forum/go_quote.gif When and if you guys get around to playing around with optical vs. coax digital cables, try different lengths of coax, particularly one at or above 1.5m vs. a short one. See if they sound the same... Cables don't "add" jitter. Impedance mismatches do. This involves more than the cable and the connector type. |
