Maxvla
- Dec 26, 2002
Unless the sound card has a dedicated premium headphone amplifier (some do, most don't), the headphone output of sound cards are all fairly the same. The power output of a computer sound card just isn't enough for quality headphones. Going back to the FM radio example a sound card output would be like the edge of reception, thin and poor dynamics. Interference from the computer is the #1 reason people use external sound equipment when using computers as sources.
Differences between DAC/amp are the dac chips and opamps. Algorithms are actually different usually. Most are proprietary when dealing with purpose built items like external DAC/amps.
Questions are fine! Don't stop asking til you know what you want to know.
Originally Posted by freedomflyer /img/forum/go_quote.gif Also, (this is so bad, all the questions...I'm just trying to dig in for a couple hours so I can have a base to ask more questions and serach out more answer) my brother owns a Dell XPS m1530 laptop that has an HDMI-out and seems to have quite the decent sound card, it is a good gaming rig. Would there be a noticeable difference if I plugged my earphones into his computer, compared to my $500 HP laptop with a stock sound card? It should affect the sound, because the amp/dac is of higher quality, but if I am correct this will NOT affect the "background noise"/"buzzing" coming from the computer because that has to do with CD/HDD/Power problems. But the actual QUALITY of the output sound is dependent on what MAIN factors of the dac/amp? The algorithms are probably the same across the board, so quality build components are what matter most? Ick, I feel kind of guilty asking all of these questions, I'll stop soon --- after I figure out the meaning of life and also the missing link...good? |
