Originally Posted by Garbz /img/forum/go_quote.gif
45% speakers, 30% amp, 20% source, 5% all others is how I roughly split my system. Not taking into account DIY projects.
That sounds about right. Although for a stereo system, I'd probably put a bit more in the source and the amp. Also, I'd put more into the source than the amps. Your speakers are only as good as the signal out of your source and most speakers scale very well with increasingly high-end sources and amps.
I reckon the sound-producing elements (eg speakers, headphones) effect the sound the most. Next would be the source and then the amp. Cables and power are the last things you should think about even though they're important. How much you spend on each is very difficult to say. It really depends on synergy of the components.
For example, my electrostatic set-up is very unbalanced money-wise, but it sounds wonderful! I'm sure it could do with a better source though.
M-Audio Audiophile USB: $150 (12%)
Stax SRM-006t Mk1: $600 (46%)
Stax SR-404: $370 (29%)
Chord Cobra 3 RCA IC: $110 (9%)
Russ Andrews PowerMax power cord: $50 (4%)
Total: $1280 (100%)
Adding a Stello DA100 ($700) would push the total to $1980 and the distribution will look like this:
Digital Source: 8%
DAC: 35%
Amp: 30%
Headphone: 19%
IC: 6%
Power cord: 3%
One could argue that the latter configuration is more balanced from a purely monetary point of view, but there is a great deal more than money IMO. Certain components may be over/underpriced, which might effect the final ratios. Take BJC ICs for example, if a large cable company (eg Transparent, Nordost, Van der Hul, Chord, Cardas, etc...) sold the exact same cable but made it look fancier, there's no doubt that the price will be much greater.
