Spyro
- Apr 15, 2003
Yea, it just seems like a packaging change. Virtually no mention or any info on sound differences or drivers or tuning of drivers.
From facebook: "UM Pros are tuned a little differently than UM Series with a more refined sound signature."
It's not much but it's a start.
My 10 pros should be here in a couple days.. I guess Friday. Westone has been show shipping my order. To be honest I'm not expecting they will be very good. Also, I never heard the UM1 so I can't compare to that.
The UM1 model is what the new Pro is replacing.
If they are essentially the same (minus a cable change) then the original can be found for half the asking price of the 10 on Amazon (mind you at that point a RE-400 becomes a much more appealing choice).
Spec-wise the PRO 10 are 20-16,000 on the F.R. where the UM1 was 40-16,000. I guess we might see some graphs, possibly some A/B to see how much better the extension is over the old model as well other differences in presentation.
Well, spec-wise PRO 10 are very similar to Westone 1, and those are no better than UM1 in any regard, same boring, flat sound with rolled-off highs and lows.
I will be glad to be proved wrong, but it looks like the only differences with old models are new cable connector and a minor face lift.
