- Oct 6, 2013
Hey, great write up and thread (and not dauntingly long or out-of-date-old)!
I'm on the hunt for my, uh, um, *cough*endgame*cough* IEMs and the UM Pro 50 recently came onto my radar. So far from the description they look pretty much exactly like what I'm looking for.
My one concern is the durability-- it seems like the one common complaint to some of the other Westone models. Now that you've had them for a year-ish, how does the durability seem? I've seen complaints of the thin nozzles snapping off. Is that a legitimate worry? Is the plastic (acrylic?) shell confidence inspiring (or at least not discouraging)? I have one metal IEM and I'm honestly not a fan (too heavy, cold).
As to the sound, you call it more relaxed than some of the other models... I assume that the bass is still able to hit big and hard when needed, though? And that the treble is pretty well extended and present, but not too aggressive? Specifically, I'm looking for an all-arounder that's got extension and power at both ends, but not so unrelenting that I couldn't listen to dusty vinyl, for example.
Regarding the sound, that's pretty much what you are looking for.
With a build quality and the nozzle, ever since I had my first Westone, that was always a thought running through my mind because Westone and Shure nozzles have the same small diameter (and you can interchange eartips). But I came across maybe one post where something happened to Westone nozzle, while other posts usually talking about nozzle concerns, not the actual problem. Personally, I'm not the best example because I'm a reviewer rather than consumer, so I don't spend too much exclusive time with one pair of iems at a time, but I do keep tabs on many head-fi threads. As you know, people more eager to share problems than praises, and if there is a wide spread of nozzle problems we would be reading it in many threads, but it's not. And for sure, this 2nd gen is more durable.
