k923
- Sep 29, 2010
First let me say thanks for the great forum. I have really learned alot about headphones, iem, etc. Yet still a big noob. Anyways on to my question. I was looking for a pair of IEM's I have narrowed it down to these to I think based off alot of searching. Here is my main questions about these two.
My priorities would be first comfort, I'm a side sleeper and would like to have them on when I lay in bed, also for travel. Second would be build quality, and last would be sound.
1. I know the sound differs alot between them, I have heard that the SE215 has a fun sound, not sure what that means. I will mainly be listening to podcasts, rock, some hip-hop.
2. It seems that these two are some of the most comfortable headphones around, but can somebody who has both compare the two in terms of comfort.
3. Same question as 2 except with build quality. The SE215 has that new removable cable, which makes me skeptical that it will be strong enough to maintain a good connection. I have seen that the SE215 have some build quality problems before, nothing really on the westone 1's. Are they both good in build quality but one is still alot better.
My last question is I have an iphone and if I got the SE215 I was thinking about getting the iphone cable. How is the cable is the mic/control to big, or is the quality of this cable worse then the original.
Thanks again for the help.
