TzeYang
- Mar 19, 2006
I encountered a very very weird problem with the dc offset measurement with my 3 channel diamond buffers, with AD744 as ground channel opamp. No gain stage.
Based off the diamond buffer design below:
Problem:
Situation One:
-Measuring directly from the bare output wires soldered on the board. however, the bare wires are not soldered to the output female jack yet.
-Black Test pen on output Ground, Red Test pen on output Left or output Right.
-Active Ground measured from input ground to output ground.
Results:I get decent Offset values, around +8mV per channel, 0.001mv on the active ground channel.
Situation Two:
-Measuring using a male to male interconnect connected to the output jack.
-Output jack is already soldered to the bare output wires.
-Black Test pen on output Ground, Red Test pen on output Left or output Right, all tested via the male interconnect output.
Results: DC Offset values are insane. +100mV on each channel.
Situation Three:
-Measuring using a male to Left and Right RCA interconnect connected to the output jack.
-Black Test pen on output Ground, Red Test pen on output Left or output Right, all tested via the RCA Male interconnect output.
Results: DC Offset Values are normal.
Situation Four:
-Again, similar to situation one, measurements are taken from the bare wires not soldered to any jacks.
-DC Offset is measured from:
~Input Active Ground to Output Active Ground
~Input Left to Output Left
~Input Right to Output Right.
Results: DC Offset values are normal, around +8mV on L and R channels, active grounds remain around 0.001mV.
Any ideas on what happened? >.< this is insane!!
I took a risk and plugged in my KSC 75 and it sounds wonderful. No distortions, no background noise at all! What really happened?
Problem:
Situation One:
Situation Two:
Situation Three:
Situation Four:
