Triode User
Member of the Trade: WAVE High Fidelity
Hi Rob,
Does a metal braid around the BNC cable have a similar effect on RF as the Ferrites?
Some users on ComputerAudiophile report good RF filtering results on DC/USB cables and I am guessing the same would apply to a BNC cable delivering digital data.
There is a so called "JSSG 360" cable modification; after John Swenson, which has a dual layer metal braid with a dielectric sandwiched in between but connected at both ends to create an electrical loop. The shield is not connected to the connectors at either end but "floating".
It's difficult to see how that "JSSG 360" shield could act in the same way as ferrites or as effectively as ferrites themselves. I think whole areas of electronic design and manufacture would have sussed that out if it really worked. I am slight suspicious of the whole "JSSG 360" thing anyway as the test results I have seen say it is not significantly better at shielding for RF compared to just plain braid or even braid earthed at just at one end. Beware the internet myths.
