Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Ferrites or inductors on digital signals have no downsides; they will either make it sound warmer by reducing noise floor modulation, or have no change at all in SQ.
Not so with analogue.
All ferrites and inductors are non-linear, where the inductance varies with signal current; and this is important because the phase shift then changes with signal level; this creates phase intermodulation distortion; and this is audible because the timing of transients becomes amplitude dependent, and the ear/brain is very sensitive to this.
Now RF is very important to amplifier electronics - and the RF on the OP cables can have an influence on the output amp via the feedback connection. I treat for RF from the OP to ensure that it is mitigated against - and this is done without using inductors or ferrites, as these in the past has had a problem with SQ.
So my advice on RF treatment on the headphone cables is to be extremely careful - brightness, or false perception of transparency, would indicate problems.
