So my experience suggests that I agree with the other posters; fix room problems with room treatment.
I primarily listen to my system through a Blu2/DAVE and a pair of LCD-3s
, so I am now frantically chasing that sort of absolutely stunning performance for a wider audience. Yet the more I think about this the bigger it appears to my simple (non-technical) mind the problem is
Leaving aside the aesthetics and WAG acceptability or otherwise of treating a room, the problem extends to any DSP that occurs after the DAC including, for example, active electronic crossovers for loudspeakers. At the HiFi meet where I was privileged enough to chat with Rob, a company (Kudos?) was demonstrating active loudspeakers (with NAIM gear I believe) which sounded very good indeed, and so in that case there is an ADC-DSP-DAC process occurring in the crossover units, downstream of the
primary DAC
So am I right to say that in that case you are listening primarily to the DAC in the crossover?? And if that is true, then if (like me, Sanders Model 10) you have active loudspeakers it makes no difference the 'quality' or nature of your upstream components (endgame DAC, turntable or whatever) you are
always listening to the DAC in the crossover
That doesn't seem to be intuitively right to me somehow, so have I got it wrong at some technical level?
Triodes and horns anyone ?
