@Rob Watts you mentioned in a previous reply that the charger has been developed specifically for the Mojo's desktop mode. Which charger are you referring to?
“When the battery is fully charged it will go into desktop mode - and unlike Hugo 2 the battery is disconnected to preserve battery life. That meant I had to improve the PSU regulation/rejection and design the charger so that when in desktop mode it was a low impedance high current power source.”
I meant the FPGA charger circuit within Mojo 2, not the PSU charger. I should have been more precise - a lot of time and effort went into the FPGA charger, and I just refer to it as the charger.
Rob, is there any other measurement slides you can show? Jitter, linearity etc
Unfortunately I did not record my measurements, but I did do a 16 bit 3 level plot:
Note how similar the left and right plots are - the ringing you see is exactly what one should see for a bandwidth limited signal. The 16 bit levels are perfectly reproduced.
My question about future Mscalers was actually whether Mojo2 will be compatible with it/those as well?
Sure
Comforting to hear that M2 will drive "REAL" headphones like HD800 and Dan´s Stealth too.? Really? Have you auditioned Stealth yet?
If so,what is your take on it?
Unfortunately not. But will hear it at NYC CanJam. Am very much looking forward to that and Singapore CanJam.
But ,what about the quite a bit more difficult to drive HEKV2 which is the headphone I use on a daily basis, will it cope with that one as well?
You will get 99.3 dB SPL from the HEKV2 - almost identical to the HD800.
Regarding no charger I only auditioned Mojo a few times and realized it was not as good as my Hugo1 and was not aware that no charger was included with it.
Why not?
And how to charge it?
Cost - this is an audiophile product sold through normal audio channels. It would have meant an eye watering increase in retail price.
You can charge it with any USB port that is capable of 0.5A. Of course, if you want quick charge time and full charge you need a 2A charger with a decent USB cable.
I'm interested to know more about this; without going too deep into details, can you briefly summarize which factors are involved in making direct coupling superior to capacitor coupling, thank you.
I also wonder why the original Mojo wasn't designed with direct coupling if it is more transparent than a coupling capacitor, but that's a question for Rob Watts if he wants to tell us...
Coupling capacitors have a few problems - one is increased distortion at bass (20Hz I use as a test) and that's due to the capacitance value changing with applied voltage. The second is dielectric absorption, where charge is discharged some time later than it should do. These two effects accounts for the soft warm and slightly imprecise bass when using coupling caps.
The issue on Mojo was power dissipation, as it needs the FPGA ADC and the digital DC servo, which would significantly increase power dissipation. With the power savings made elsewhere I could now do this.
Thank you.
Evidently Chord and Mr. W had decided on a second USB input.
It is the "Why!" bit I don't get.
Most people, use one input and stick with it.
I suppose, if it had a remote (like Hugo2), then it could have acted as a center piece in a desktop system.
Does Chord have a large inventory of Poly's ?
I wonder.
Because some are crazy about USB C, and we had to make it compatible with Poly.
I don't understand it as every USB C device I have had had connector reliability problems. Indeed my son just came up to tell me just 5 minutes ago that his 18 month old phone won't charge - it's the USB C socket failing...
