GryphonGuy
ice-cream making machine is the end process but in this case, DAC is the end process. if you want then mouth/ears will be the end process, respectively.
Until now, you still didn't got the HMS?
I don't think you understood my analogy or the reason I made it up.
Mscaler is a combined hardware (very specialised hardware at that) and software solution that upscales the resolution of digital music in realtime (as and when it happens). The resulting up-rezzed data is usually fed into a DAC within milliseconds or less after it is created.
PGGB is a combined hardware and software solution (just like Mscaler but the hardware is an ordinary general-purpose computer) that upscales the resolution of digital music offline. The resulting up-rezzed data is usually stored as in a file and will be processed through a DAC later.
So effectively Mscaler and PGGB appear to be competitors because they do similar things and achieve similar outcomes but each creator will say they are very different. Competition is great.
So from my point of view I needed a "story" to let you know a similar scenario that I hoped would make it easier to see what I was saying.
Both Mscaler and PGGB are doing similar things. If you really do want to process PGGB files through the Mscaler, then you should also want to record the Mscaler's output and pump it through PGGB as well. If one seems an odd approach to you, then they both should be seen as odd approaches is what I was trying to say.
Just for the record, despite multiple auditions of Mscaler, I always found the bass notes to be "off". very recessed and seemingly divorced from the rest of the music. When I tested PGGB, the very same effect was at play. So after much investigation and testing and to cut a long story short, replacing my headphone cable with a Lazuli Nirvana corrected the bass note problems and has brought my up-rezzed listening to new levels of realism through my DAVE.
I hope this clarifies my simple analogy in a previous post.
Regards
GG
