My feedback on Jitterbug is that I only notised a difference when I used it with MBP from 2013 with a short curious usb cable, i know should be snake oil, but it was not, curious cable made big difference and the jitterbug mad small difference, blacker background but rolled off treble, so depending on what I streamed, Tidal or Qobus it was give or take, some songs sounded better with while other better without, at the end I left ut on as I generally prefered it more pleased with it than not ( i use HD800), that said with any other source I have not used it since no benefit via usb, though the short curious usb cable sounded better than any normal generic one I have, checked 10 + cables and was surprised....of the difference with the MBP, never been a cable guy as I always thought it was and is snake oil, but would recommend if using direct with a PC, laptop or similar! Cant say why but it does....my 2 cents...
