regal
- May 27, 2006
All in all the Win 7 trial is pretty sweet. Trying to figure out how much it is going to cost to buy it and if I'm going to have to start from ground zero
Originally Posted by Ham Sandwich /img/forum/go_quote.gif How are you verifying bit perfectness using the DacMagic? The DacMagic doesn't do HDCD so you can't base a test on it lighting up its HDCD light. The lights on the front of the DacMagic just show you the incoming sample rate, not that the incoming data is bit perfect. You could feed the data from the DacMagic to a second DAC that does do HDCD to verify bit perfectness that way. |
Originally Posted by Omega17TheTrue /img/forum/go_quote.gif foobar2k with WASAPI is NOT bit perfect, the foobar's volume control deform the sound, i notice a HUGE difference using kmplayer with reclock on wasapi, i will make a tutorial |
Originally Posted by Omega17TheTrue /img/forum/go_quote.gif i will make a tutorial to configure it for having a top-notch video/audio player. |
