r0msk1
- Jan 7, 2015
oh, forgot to mention, it's not V2S. i own a V2 with data port.
I thought DAC starts on V2s?
well, i guess there are some V2 with this feature, too. but, maybe in V2S it's made better.I thought DAC starts on V2s?
I am reading through the most recent comments on Walnut's official Taobao page
https://world.taobao.com/item/542124740337.htm
and some comments on V2s are still saying bass is rolled off, just FYI
Im new to diy DAP/AMP can i ask a few questions??
How can i connect this to a phone use it as an AMP, use On-The-go usb or normal audio jack??? And is it the same on computer??
Does walnut have a dac?? And how can i use it???
Can someone describe how the eq is and works? V2S
Im hoping it has a mode where the bass is tight with that soft smooth tsss noise to it, and without sacrificing miss and vocals, they should be loud and well defined, separated, also I love treble.
I think it means that the bass is a bit obscured while the mids are not and vocals are forward.
so far, I have a hard time recognizing eq and their changes. <2 hrs of playing
For people who have the Walnut V2S, when you turned it on, you will hear female voice saying in Mandarin, "Musical Mode". If you press the EQ (equalizier) button, you will hear "No Equalizier" which sounds like "Five" in Mandarin. "No Equalizier" gives one syllable.
If U press 2nd times, you will hear "Rock and Roll" in Mandarin. Press 3rd times, you will hear "Pop" . Press 4th times, hear "Classical" Press 5th times, hear "Jazz". Press once more, back to "No Equalizier" mode. "Rock and Roll", "Pop", "Classical", "Jazz" all give 2 syllables.
If U press "prev" and "next" buttons together and hold for a while, U will hear "last folder" in Mandarin
