Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-13522032
Post #3,076 of 3,580
EGO DEATH
Underworld
Underworld
All of a sudden, my V2S won't play music with the same card inside, does anyone else encounter the same problem? Any suggestion? Anyone knows how to reset the player or some kind of firmware update? I never have problem with the V2 version 2...kind of disappointing on this since it's not even a month yet....
Just curious, where did you purchase it?
post-13522093
Post #3,077 of 3,580
Dark Helmet
just reveived my Walnut V2, but it looks different from what i've seen on the net, is it fake?
pictures here: https://imgur.com/gallery/5NIvP
Well there was the standard Walnut with socketed opamps, then there came the soldered on opamp which wasthe OPA2604, then back to the socketed opamps with the data input in the back and no hold switch, then the 5 button Walnut, and now this iteration, which has the power switch on the back which looks new. I count 5 versions.
Reactions: Sopranino
post-13522127
Post #3,078 of 3,580
silverfishla
Los Angeles
Los Angeles
Does anyone know what kind of FLAC files the V2s is able to play? I haven't seen that in the specs that I have read. Can it play FLAC 24/96, 24/192, 24/44.1? Can it play DSD?
post-13522262
Post #3,079 of 3,580
yangian
It cannot play 24/196. Not sure others
Reactions: silverfishla
post-13522618
Post #3,081 of 3,580
makima
it has RC5532 op amp inside, socketed.
post-13522732
Post #3,085 of 3,580
makima
Just looked on google and it says that it is a Fairchild, which in my opinion is better than the Texas Instruments version.
mm, can you post a link with your findings. a re-googled just now, nothing. maybe i'm just not that good at googling as i thought i was))
post-13523012
Post #3,087 of 3,580
ozkan
Still no V2 vs V2s comparison.
post-13523059
Post #3,088 of 3,580
makima
tried using Walnut as USB DAC. very bad sound quality, as for me.
using PC with foobar2000. same song is way clearer on the player itself.
post-13523081
Post #3,089 of 3,580
r0msk1
Oh that's a bad news, as my V2s is arriving tomorrow (again). It failed to arrive today.
